Help identifing pistons in 400
oak
Hello I'm new and have recently been working on my 79TA it has 400 Pontiac and 4spd have disassembled the engine to check and see what I have. it looks as though the engine is original and only change to it other than the #16 heads are cam and pistons I am going thru engine but pistons look great and would like to know if anyone could help to identify them? I also need idea as to what cam I should use for street diving? I know that's a big question so disregard if you like . Any one in Toledo,Ohio area know of Pontiac engine guru?
I have a machine shop already but they say chose what cam u want. I don't think to much will have to be done to engine ,it did run good but had a vibration found a problem with clutch and will have every thing balanced .they are a great machine shop I have been working with them for years Ill think pistons are good bore is great, heads look as though they where just done. I find it a bit confusing to figure out what cam to use though . Thanks
the cam choice depends alot on what the other components are. what compression, what intake, what make and size carburetor, what transmission, auto or man., what rear end gears.
