Help with 2005 Pontiac Sunfire
  • Thread starter Thread starter roo0105
R
roo0105
Horn? Fri night, my fiance was on his way home and a black dog ran out in front of him and there was nothing he could do but hit it. The dog hit the lower part of the front and passenger side plastic fender. So most of the dents popped out, but ever since then, my horn has stopped working. Does anyone knwo where the horn is located in the 05 Sunfire's? I dont know if maybe the inpact knocked something loose. I have checked the fuse and it is fine. Even replaced it just to be on the safe side. Then this morning, I honked at a friend, and it actually worked. But then tried and it stopped again. So i think something may be loose, but not sure. Any ideas???
Probably damaged the horn or loosened the mounting bolt enough to cause a bad connection...
low hits on the front can cause damage very easily..
