Please if you know how to work on the REAR brakes on an 02' Pontiac grand am se please give step by step instructions on what we need to do. I have looked on line and can not find any helpful information.
Not hard to do, check out a repair manual site, will shoe you replacement, and adjustmentsm and needed parts. Also try to go get a free estimate from a brake shop, many of these are free, and will give you a general idea, what needs to be replaced. Good luck
pads or shoe if disk type in
how to replace brake pads
how to replace brake shoes wil get how to and its about the same on every car made really easy once you know one you can do any car here is both ways im sure you can find others just type in how to replace brake pads or how to replace brake shoes and if you add video to end of that even find one also like
how to replace brake pad video
how to replace brake shoe video
wil lget all you need to know most all car brakes are the same way some bolts or pins change but how it works stay the same som edo have screw in type pistons will know that if there is a notch cut into them for that type will need to rent a tool onlty a few type of cars have them but either way brakes are easy most anyone can do at home
