I agree, if you have to replace the rod bearings, the crank is more than likely shot as well. Possibly more than could be ground off to repair it. Then you have to find out why they're bad to begin with, bad oil pump? bad cooling system? sludge in the motor blocking the oil pathways? Either way its a motor rebuild or a different motor so check your wallet first!!
