need to remove the head to replace bent rod on a sunfire 2.4L. have the cams off, timing chain cover and chain all removed. cant figure out how to get the rear housing off removed all the bolts i can see including the 1 under the tensioner. it wiggles but its still held on to something is there components holding it on around the outside ?
using the online maunals on autozone and it only shows the cover removal cant find anything on the rear housing
