How to replace the air filter housing??
Jefe22
The screw holding the top of the filter is stripped so I'm replacing the whole housing but I need help!! Anyone have any links or steps to removing the housing of a 2001 pontiac grad am se 2.4 engine coupe??
Here is the diagram for the air box. Most of these air boxes will come out with a good heave-ho. Disconnect it from the throttle body and have a look around for bolts holding it
I believe it has only one not sure ill check in the morning thanks
