I have a 1990 Pontiac Sunbird that was retro fitted with 134A freon.?
gdun36
This spring it leaked in a seal that was fixed.I need to refill in with freon.In order to fill it I need to get the compressor to cycle.My question is what wires do I need to put a jumper wire on to cycle the compressor.The only place I could find is a relay on the firewall.Any idea which relay I should do it on because there is 3 different relays...
don't jump the compressor, you could ruin it. it needs freon for lubrication. put freon in it first when theres enough freon in it the compressor should kick in.
