finally
its been a few weeks, but i have a little update:
i fixed the wiring issue, after i pulled the motor! >_>
after i got it running decent, i took it out and heard the clutch slip. so my friends and i got a few days off and pulled that sucker out. (which i'm sure you all know, is very fun when you dont have a shop.) the clutch disk was put in backwards!!!! omfg. also the front transmission mount braket was beat up all to hell! it was a brand new clutch tho >_>. anyway, changed the disk/plate/throwout bearing, checked the fork bushings (which i read about earlier), replaced the rear main and oil pan gaskets, redid the camshaft seal, and cleaned 10 pounds of grime off the inside and outside of the transmission. also replaced the alternator, which ironically decided to kick off the same day. two days later, she starts up and purrs! i hooked up the diagnostic terminals, and revved it up to reset the IAC, and the motor sounds great.
tried to bleed the clutch but what came out of it was pure grey/black. i only had a small bottle of dot3 with me, so i ended up having to reuse alot of the old fluid, which i'll replace tomorrow. right now i have to start it in gear, and i belive that has to be the old fluid.
other than that and the transmission bracket, the car is good >=D
tomorrow i replace the fluid and take it for its first test drive on the street^^
thanks for all your help =D
