oldandretired
- Dec 15, 2016
04 Grand Am GT, V6. No trouble codes. Cleaned MAS air flow sensor, new air filter. Engine starts right up and idles fine when cold. When engine temperature gets to about 160 degrees or higher, the idle surges up and down, and the engine occasionally dies. Starts again with foot feed held slightly open.
'Have read dozens of posts about IAC's, but all indicated rough idle.
Is there a temperature sensor that tells the ECM to change parameters? Could this temp. sensor be the culprit? Thank you!
