I finally got my 99 Montana up and going. Had to replace the hub/bearing, tie rod ends, rotors and brakes. It's been down for about 2 months. It's been below 0 degrees so I've been working on it here and there. Now the air only goes up through the defrost vents regardless of the position of the selector. I checked the fuses and all are good as far as i can tell. It's been sitting for the two months with the front end jacked up higher then the rear. Coould this have allowed water in to the systems and possibly froze everyhting in the spot? Any ideas would be appreciated.
Jeremy
Jeremy
