Inside door panel remove
je2wheeler
I have been studying how the door panel comes off, after I have removed the two plastic access dodads and all visible screws and upper door lock pull, It seems the panel should come off after freeing any hidden clips that I can not see and am afraid of snapping something off in the processes.
In other words - - HELP!
(1) Remove the inside door handle bezel plug. This is the trim behind the door handle. Will find a screw there.
2) Screw at the end of the trim panel, door openning end.
3) Remove the door trim panel cover. This in the piece just forward of the handle. Will find two screws there.
4) Using a door trim clip remover, remove the trim panel with the 9 retainers. Keep near the door.
5) Pull up on the door lock retainer to disengage
(6) Disconnect the electrical connectors.
exactly as posted unless yours is an early 2006. Then it it slightly different. I have had the door panels off of my early 2006 & my 2009.
