instrument panel lights went out
91 Formula
Posting again to see if anyone has any suggestions. My instrument panel lights went out suddenly, the fuses are ok and I made sure the dimmer switch was turned all the way up. Anyone have any ideas? Its hard to drive at night with no instrument panel lights
without basic tools, a test light or volt meter, how are you going to trace down the problem? A test light is maybe a $20 investment.
is just the dash lights that are not working...??
how do you know fuses are good.....
melesg5 is right you need a test light to check fuses(must light on both sides of fuse)
and i do believe dash light have there own fuse
hope this helps let us know how you make out
Yes just the dash lights. All other lights are fine. I'll double check. I'll get a test light and check it out again
