Dr. Sievers
I noticed that my wording sounds newbish so I wanted to cover this question a little better. The intake hose that starts from the vent and follows up to the air filter. If this hose was to be removed and just the airfilter in place would this be an improvement over stock as far as longivity? Some engines respond to more air flow better than others. Also would this effect the manifold cooling vent hose? The hose that disrupts air from the intake hose and blows it directly on the manifold.
The reason for this idea was that if this will improve my fuel economy and lifespan of my engine without causing my manifold to overheat I'd probably do this the minute I walk out of work, but, if not then I want to just leave it be. And I know that the car gets killer fuel mileage, but, come on if you can get more out of it your going to try, right?
