Intermittent Tranny disengagment
Moejo
Seattle
After coming to a stop , tranny occasionally disengages like put into neutral, then car must be put into park and shut off. When restarted works as should. Does not seem to be a heat issue, as happens when cold or end of a trip. But very intermittently.
No idea what year you are referring to but have you checked the fluid level?
How many miles since you changed the fluid and filter?
This is a 1999 bonneville
did the problem exist before the filter and fluid change?
did the shop make any comments on the condition of the old fluid or anything found in the transmission pan?
did the shop scan the transmission for any codes?
how many miles on the car?
this site lists some common problems with the 4T65E transmission
http://www.gmls4.com/index.php?topic=2773.0
