My 2006 pontiac torrent awd is leaking oil from the bottom plate. I took it to the mechanic he said the engine needs to be dropped down so that he can change the oil seal. I'm afraid of the complications that normally follows whenever engine is dropped down. Pls I need your advice. Should I just be topping up the oil everytime or should I drop the engine to change the oil seal by the side of the engine
