Hello, I have a 2000 Grand Am 2.4L, that used to only misfire when I hit the throttle hard. One day it started misfiring all the time with codes P0300 and P0141 (SES flashing and trac light on). I pulled out the fuel injector elec connectors one by one and determined Cyl. 1 was misfiring. So far I swapped plugs, switched coil packs around, switched fuel injectors 1 and 2 around, verified fuel injector was getting power with noid light, and compression tests give about 150 psi in all four cylinders. Still Cyl 1 misfires.
Any Ideas?
Thanks
Any Ideas?
Thanks
