Joshschneids
- Feb 27, 2013
Just recently go a 2000 pontiac montana, fixed the head gasket leak, 3/4 of the time my heat works but the odd time ill drive from my house to my grandparents which is about 1 and a half km and the van will pin the needle in the red and my hot coolant level light will come on. If I pop the hood and look at my coolant reservoir it is almost full. Then if I keep driving the temp will go down sometimes. I I come out and start it 10 minutes later it will be fine coolant is regular level and it blows hot heat. What is causing this problem? Have thought of an air lock because if air expanding and pushing the coolant into the resivour. Sorry for the long explanation but I have troubleshooted this long enough an have become frustrated!
Any help would be appreciated! Thanks, josh
