Transmission! Until you have the cash to fix it get a small bottle of brake fluid and add it to the transmission fluid. It will fix it for about 4 weeks! Depending how much you drive!
I highly do not recommend putting brake fluid in your transmission! Check the fluid level of the transmission, hot with engine running. If low add fluid to indicator line. If that is not the problem time to tow the car to a repair shop
