My 96 Pontiac grand am GT wont start when its warm? I have checked the mass
  • Thread starter Thread starter Krull
K
Krull
airflow, and the EGR vaulve.? It will run when it is cold and still wont die when it gets hot, but If I try to start it a little whistle after shutting it down warm, it will have a rough start and sometimes stall. I was thinking loose seal in the gasket? Or mabey bad pistons?
I was thinking it was the coil? but would that make it start hard when its hot??
my check engine light is on
Is your check engine light on? From what you said it sounds like it might throw a id10t code, its an easy fix.
