Probably a weekend warrior my budget is not limited but I'd like to keep it as original as possiblewelcome to the forum and congratulations on your new car. Mod suggestions are only limited by your budget and what the primary use of the car will be. Good luck with it.
Awesome ill check those outMods and original as possible? I would start with a simple advance weight kit for the HEI distributor setting the total mechanical advance to 36 degrees. The carburetor secondary rods could be changed for a richer full throttle. For the suspension you could look into Koni or Bilstein shocks. There are lots of articles in magazines but typically it involves carburetor and intake manifold changes plus lower restriction exhaust, headers.
