Mystery oil seepage
pippo
Active member
Florida
Guys,
Oil is collecting on the bottom of the starter motor. So strange, as I cant figure out where it is seeping from. The valve cover gasket is clean. The shop manual shows the starter sprocket teeth above the rear engine seal so I dont think it the seal as one would also see seepage/oil draining all over the bottom of the flywheel, which is clean/no oil stains.
Where could this oil be coming from? Ideas welcome and appreciated.
If you want they sell kits where you add a dye to the oil and then use a UV light to find the leak. First you have to clean the area.
Great tip Mel, but I already did that- cleaned the bottom of the starter motor nice and dry, added 4 mls dye, ran the car for 20 miles, and oil collecting right away under the starter. With a dye light, it fluoresced yellowish, proving the oil, and not something else. I kinda figure that anyway. But I still cant figure out from where. That starter gear sprocket has to be above the crank seal, from memory. Never seen this before, ever.
Thanks.
What engine do you have in the car?
2.0L non-turbo. Struggling to find what is causing the dripping onto the bottom of the starter. rear engine gasket does not seem to be leaking oil. Such a mystery.
Thanks.
Ok what car model & year and what engine Model specifically Like a 2.0L NA LT2 engine? With just a generic 2.0 NA GM engine it is hard to pin down.
Is the started located below the intake manifold? If so I would check the PCV valve fro cracks or a bad gasket. Just a guess without knowing the exact model of engine. Good luck
