need help with pontiac grand am?
Eliseo D
i have a pointiac grand am ce 2000
with a 2.4L engine
it turns on but i dont get any electrical pulse in the injectors to get the gasoline it needs.....how can i fix this problem/??
Check the wiring going to the injectors and it could be the main comp is faulty , also you may have a faulty sensor so have the system scanned if you can.
Hope that helps and best of luck.By the way is it trying to start , is it turning over properly?
Could it possibly be something to do with the anti theft system on this car? does your key have a little plus sign on it? It sounds alot like a problem I was having with my Cougar, and it turned out that my keys transponder went bad......hope this is of some help
