Need help with temperature gaurge in 1974 Pontiac
Did you try grounding the wire connected to the sensor, if the gauge moves the sensor is bad.
Yes it moves the gauge when I ground it and have replaced the sending unit but still cannot get gauge to work bought two sending units know but still can't get gauge to work.
Are you putting anything on the threads of the sending unit?
What manufacturer and part number sending unit are you using?
The sending unit came with tape on it I was wondering if that was killing my ground.
Sure sounds like it killed the ground, do what 92 Sunbird said or remove some of the tape
Thanks will try it .
