Hi Folks. Why won't my 2000 Pontiac Grand Am start in wet weather? It will not crank in this condition and usually none of the electronics will work at all. I can only get it to start when I disconnect the positive terminal of the battery then try to crank it while still disconnected, THEN hook the battery back up and crank it (trying to crank it while the battery is disconnected is required for this trick to work). Any ideas which component is the soggy culprit?
Thanks,
SS
Thanks,
SS
