hey everyone. i just picked up an 02 sunfire and the car honestly has me stumped. the car was throwing a code for the map and upstream o2 sensor and i fixed that. it runs great, and will drive fine in reverse but when you put it in first gear its like your starting the car in 5th gear and will either stall or have no power. the only code that will come up at times is the secondary o2 sensor but right now it doesnt have a cat on it so it could be from that. i've replaced the icm and the coils and that didnt change anything. also the car is a manual trans and all the gears are there. its getting very cold here in upstate ny so i need to get this done asap so i have a car so hopefully someone here can help. thank you
