I have an 99 trans am WS6 with no spark. Car was sitting in driveway idling and it just shut down and would not restart. I bought the pontiac service manuals and I have confirmed grounds to the coils and PCM blue pins 1 an 40. Also positive battery voiltage on blue pins 20 and 57 and ignition positive voiltage on pin 19. Grounds on the red on 1 and 40 was also confirmed. There is 12 volts to coils. All fuses and relays test ok. PCM was replaced with a known good one. Crank sensor is replaced. I have injector pulse when cranking and fuel pressure? It seems to me that the PCM is not sending the signal out to the coils. Could it be in the pass key system? If so, how do I test it? I don't know what to check next. I'm tired of seeing it just sitting there. Please help. Thanks Ron.
