I have a 1985 Fiero GT 2.8. Reasonable miles on the machine around 60000 miles, in very good shape. I just purchased the vehicle as I had a 84 4 cylinder as my first car so I thought I would give it another go 24 years later.
I have had a couple of issues thus far. Oil leak on the passenger side forward the motor, seems to occur when the engine cools down in the garage. Also another oil leak on the left rear which appears to be a lighter colored oil.
The chieck engine light comes on the odd time when the vehicle idle finally gets down to about 1100 rpm.
Ignitiion colar needs to be pushed hard sometimes to start the vehicle, but other times not a problem.
Air conditioning does not work, compressor seized, condensor leaked out, needs replacement, will the evaporator be toast?
