Oil Sending Unit
Mrclean81
Hello folks. I've been a long time lurker here, and have always been able to solve my problems just from spending some time searching, but this time I haven't found much on the subject. Here's my issue. I was about 80 miles from home the other day when the low oil light came on. I immediately pulled over to see what was going on, and there was a steady stream of oil pouring out of the lower end of the engine. I had just changed the oil a few days before hand, so my first thought was the drain plug or filter wasn't tight. I'm a fairly small guy, so I climbed under the van to check, and it wasn't either of those. However, everything under the van was soaked in oil and there was nothing left on the dipstick. I call a friend who lived close by, and he was nice enough to trailer the van back home. Once inside the garage, I get it on ramps and put some oil in it. Start it up, and oil is gushing from above the starter. Here's my 2 part question..would that be the oil sending unit in that area, and if so, how do I get to it? I really don't want to pull the starter, and I absolutely don't want to remove the exhaust manifold. Thanks in advance to anyone who can help. I have to get this thing on the road tomorrow or else I'm not gonna make it to work Monday.
its easier to change the sending unit if you remove the starter but you dont need to totally remove it, just take off the 2 bolts from the starter and let it hang to get easy access to the sending unit, you will need a 26 mm close wrench to remove the sending unit , before i forgot first disconnect one of the battery terminal before you unbolt the starter
