ericv1984
Ok so now I have this car narrowed down to only one code.
The CEL on my car never seems to go away, even if the problem is resolved, no matter how many miles I drive my car. It seems to only go away when I clear the codes. So today, I did that, I went to O'reilly and cleared the codes with their scanner. On my way to Fred Meyer to send out a fax, the CEL came back on which I suspected it would so I went to a different O'reilly that was closer. Hooked up their scanner, only one code came up this time which is "P0171 System Too Lean (Bank 1)". Wouldn't that make my car consumer more gas and make the MPG's go down? Cause so far the gas mileage seems fine, but I haven't let it get to low so I'm not sure.
Also, would my symptoms be linked to the oxygen sensor? Long cranking when the engine is warm, even longer cranking when engine is cold, car sometimes stalling, gas smell coming from the car (don't know where), after it stalls it takes a few times for the car to come on and stay on even though it sounds like it wants to die?
Here are a couple pictures of what the scanner brought up. Not sure what this means....
