P1125
mclaughlin0844
Ive been having a headache the last week with this car. It keeps going into reduced power mode. Codes indicated throttle body, and pedal position sensor?
Ive replaced the throttle body, pedal, and also put in a new battery. The car will drive fine for a minute then go in "limp" mode, or even stall. Now the only code it is throwing is P1125 - APP system. Any recommendations?
Did you use new brand name parts?
So, i got a TB from junk yard and pedal off amazon. The TB code went away but was still getting a pedal code. After watching the youtube video above, checked the wires, there was water in the gray thing? Whatever that was in the video. Dried it out. Taped it up…. Still getting a pedal code…. Took the new pedal off and cleaned up the old one originally on it. Car is now running normal.
