Pontiac Aztek 2004 Problems. Need Help!?
  • Thread starter Thread starter Jon
J
Jon
I got the 2004 Pontiac Aztek a while back. I love the car, and it is a lot of fun to drive. And it gets a lot of attention. But I am having some major issues with it. 1) The first problem is the the driver side break light. It works sometimes, and other times it does not work. I have changed the bulb many times, but that is not the issue. 2) Also, the turn signals are becoming a major issue. When I turn the passenger side turn signal on, they both flash. Yet, the driver side works fine. These issues only occur sometimes, but will work other times. 3) The other issue is my gas level meter. It seems not know where my gas level is for some odd reason. It will at times bounce past the "F", yet it will work every now and again (not very often though). I had a piece changed for this problem, but it did not fix it. I know it has to be electrical for all of these issues, and I really need help to have an idea of what to tell the people i am taking it to, to get fixed. The main thing is the turn signals. That HAS to be fixed. HELP!!
1. check for a bad bulb socket.
2. check for corroded ground connections.
3. what do you mean you had a piece changed? what piece?
