Pontiac G6 GT engine disabled while driving
dlwood
I have a Pontiac G6 GT 2006. The past two months it has been reducing the speed then it comes up on my screen engine disabled... It is like the security system is taking over and it just shuts off whether I am driving or sitting im my garage. I have had them put the code machine on it and they come up with nothing. They keep telling me there is nothing wrong. A few years ago I started to have issues with the auto start, it didnt work all the time and they said that was normal, it also stutters when you start it sometimes, but my main concern is the security system shutting down my car. Has anybody had this issue and how did you get it fixed?
thank you
DWood
who is diagnosing that the code shows nothing, a GM dealer or independent repair shop?
Security will not shut down a running car, you have another problem.
power reduced......engine disabled..
It is a repair shop for gm dealer. I just took it back into them yesterday, it wont run longer than 15 min and now the engine light came on.
dlwood,
Please keep us posted on the diagnosis from the dealership and if the problem has been taken care of. Thank you for your time.
Caron, Pontiac Customer Service
Please keep us posted on what you find
I have the same issue with my 2006 G6 GT. Within about 5 minutes of driving my car, the engine light comes on and the radio displays Eng Pwr Reduced and then it immediately follows with Engine Disabled. Within about 1 minute I'm able to start it again and it drives fine after that. Please keep me posted on what you find the issue is with your car. I've taken my car to the Chevy dealership twice and they can't find anything.
tell the chevy dealer to look up this bulletin
Bulletin No.: 07-06-04-019A
Date: November 06, 2008
Subject:
Intermittent MIL/SES, DTC P2138 with Reduced Engine Power (Repair Instrument Panel (IP) to Body Harness Connector)
Models:
2005-2008 GM Passenger Cars and Light Duty Trucks (Including Saturn)
2005-2008 HUMMER H2
2006-2008 HUMMER H3
2005-2008 Saab 9-7X
Supercede:
This Bulletin is being revised to add additional diagnostic service information. Please discard Corporate Bulletin Number 07-06-04-019 (Section 06 - Engine/Propulsion System)
Condition
Some customers may comment on an intermittent MIL/SES light Illuminated with a message center or an indicator that displays Reduced Engine Power. DTC P2138 Accelerator Pedal Position (APP) Sensor 1-2 Correlation may be set. The voltage difference between APP sensor 1 and APP sensor 2 exceeds a predetermined value for more than a brief period. Refer to DTC P2138 in SI for further diagnostics.
Cause
On some vehicles, the IP to body harness connector, which carries the APP signal to the ECM/PCM, is located in the left hand kick panel area or inside the IP. Water intrusion into these areas could cause an electrical short in the APP circuits setting a P2138 code.
Correction
Note: Make sure that no add-on/aftermarket equipment is electrically connected to the APP signals or to the other ECM/PCM five volt reference or return lines. These can generate false P2138 and/or other ETC System DTCs. If there are other engine DTCs besides P2138, such as MAP sensor faults (i.e. P0107, P0108), resolve these first before attempting to diagnose P2138 DTCs.
Important: Refer to DTC P2138 in SI to confirm that the ETC pedal is operating correctly.
Locate the IP to body harness connector, which may be located in and around the left hand kick panel area or inside the IP. Check to see if there is a water leak into the area and repair as necessary. Use a water hose to determine the source of a water leak and effectiveness of repair. Some examples of potential water leaks are: A-pillar seals, sunroof drain lines (if so equipped) and windshield/cowl sealing. Finally, repair or replace the IP to body harness connector, making sure no corrosion or debris is left on or between the terminals.
This is a couple years later but my 2006 Pontiac g6 started doing the same thing. I took my car in to the mechanic and they said "PCM" came up on their computer. They didn't give me codes, just sent me to a pontiac dealership, which I haven't gone yet. What ended up being the problem? Did you have to change the PCM...or something easy?
As you stated the post is over 4 years old. What was the code that came up on the scanner? Ask your mechanic.
