Pontiac Sunfire 04 wont start
Smith12541
My sunfire wont start. Got an oil change and engine flush 2 days earlier and started my car in the morning. Went inside came back out and the car was off. Changed the battery, spark plugs and fuel pump relay. The engine cranks just wont start. There is no fuel coming from the fuel line valve going to the injector rail when i push it with a screwdriver. Does that mean i need a new fuel pump?
could be a clogged filter, a failed fuel pump relay, a broken wire harness, a blown fuse, or a failed fuel pump. Do you hear the fuel pump turn on for a few seconds when you put the ignition key to the run position?
