My 72 Lemans originally had bench seats. I am presently installing poweseats from a GTO. I purchased the relay from OPGI but can figure out where the wires go.
I have installed other relays in the past. This relay is designed different. Two of the sets of prongs in the front are one piece?? If you look at the relay under OPGI you'll
Understand. I called OPGI , they said they have no idea hoe it goes. Can someone explain how the wires go, or should I just use a normal relay for each. Seat?? Thanks
