Hi i just bought a 1993 Firebird formula, its a automatic 5.7l v8 with the ram air system, some times it bogs and totally loses power, mainly when im really beating on it, but sometimes itll do it for no reason.
i just figured out the mass air unit isnt on it and it should be... would that cause this issue, i had a guy pull codes cause of this issue and the check engine soon light is on, he said it gave him error with map sensor and a error with mass air. i replaced the map sensor but havent done the mass air yet as the wiring and everything is gone.
please let me know what you think it is. i would assume i need to install mass air back onto it, but id like to know your thoughts.
is there anyhting else that would cause a total loss of power while driving. it doesnt always do it but once it does it does it alot till i shut it off and turn it back on, a few times ive had it stall at a stop.
