rfincher86
- Jan 28, 2014
I have noticed that when I hit a bump no matter what speed I feel a wobble/sway/bounce from the rear passenger side of the van. It kinda makes the rear of the van move side to side. The up and down bounce is also a lot more extreme than what it used to be. I checked under neath the van and all the bushings seem to be fine. I also checked the wheel bearings and they seem to be fine. I found that the fuse for the air compressor was missing so apparently over the past 3 years of owning this van the air compressor has never worked, after replacing the fuse and getting the air compressor working it made the problem worse. I notice that the air compressor runs every time I park the van and turn the engine off, is that normal? The rear passenger side rim seems like it might have a slight egg shape to it so I am going to swap it to the other side and see if the problem follows the wheel. Does anyone else have any other suggestions?
