My wife's engine light came on about a month ago so I got my code reader to see what the code was. Turned out it was a bad gas cap seal so after a new gas cap and a month later the light is still on. Its done this before so I did what I did before..unplug the battery for 30 seconds then reconnect. BEFORE everything was fine and the code cleared. This time after reconnecting it, it won't start, the key will not come out of the ignition, you can't put it in neutral to push it anywhere, windows and lock buttons do not work and the remote doesn't work. The dash lights and radio still work when the key is on but it will not turn over. I found a release button on the bottom of the steering column so I can at least pull the key out but the radio still stays on when the key is out and even when you open the door. I can hear the fuel pump kicking on and various other relays come on when the key is turn on but nothing after that. I've been thinking it was something to do with the theft deterrent but I looked all through the manual and no luck. Checked various fuses that might tie into something to start it and all of them are good. Google has been of no help and I searched on here with no luck either. The local Chevy dealer tech said he had never heard of anything like this before. Another dealer would only tell me to bring it in...the cliche answer. I'm at a loss for what to check next..I'm a Ford guy and my wife just HAD to have this Pontiac..so I'm not too familiar with General Motors vehicles. Hopefully I can get some pointers and advice here since nothing else has been of help. Thanks in advance.
2007 Pontiac Torrent
