replacement headlights
jedeka
A friend of mine has a 2000 SE and needs new headlights. What aftermarket headlight housings are available with the black trim and headlight adjusters included? Thanks.
Thanks CatSkinner. I saw some on ebay but was not sure of quality. Did they come with the headlight adjusters?
They were the whole assembly, including the posts on the back and the harness that attaches the high beams, low beams and running lights. However, I thought the adjustment was made from the framework the headlight assembly was attached to.
My bad, was just doing maintenance and noticed that the adjusters were attached to the assembly, so, yes, you get the whole kit and kaboodle.
