One of my injectors is leaking out fuel, most likely a bad o-ring (this happened a few months ago on a different injector, knew I should have replaced all 4 while i was at it) ... I tried replacing the other 3 this week and had a hard time getting the bracket back on that holds all four of them down.
What is the trick to it?
The closest I've come to a solution is slightly taking off the FPR, putting the bracket on, then putting the FPR back in position. After doing this, the same injector is leaking, so I have a feeling the bracket didn't go on correctly and it's not holding the injector down right.
Should I completely remove the FPR?
Thanks!
Thanks!
