So I'm replacing the fuel filter in my '94 Sunbird LE 2.0L. I assumed the fuel line running to the engine would need to be depressurized since the system is fuel injected and all, so I looked up the location of the fuel pump relay, which I assume to be correct as per what was mentioned at this forum.
I started the car, and pulled the relay when it was running, and it never stalled out like I had expected it to. I assume I either pulled the wrong relay, or they were wrong, or both. I also assume the fuel line is still under pressure.
My question is, am I doing something wrong?
Also on an interesting note, I've seen a few guides specific to this car for removing the fuel filter and none of them even mention taking this step, although I assume they simply missed it in their directions.
Thanks in advance.
Thanks in advance.
