Still no spark! I changed the plugs, wires, points, condenser & coil. I received the manual in the mail and followed it down the list - 1) Disconnect wire at plug, check for spark 1/4" from engine - no spark. 2) Remove coil wire from distributor, check for spark 1/4" from engine - no spark. 3) connect test light from neg side of distributor to ground, turn on ignition - test light lights. 4) connect test light from point set lead connection to ground-open points ( this I'm a little confused on, does this mean from the wire on the points to the base of the points set?) test light lights. 5) Test the coil & condenser - they are new. Any suggestions other than buy another coil & condenser? Thanks, Rich!
