Hi All,
I have a 1970 TA, Ram Air 3 4-speed car. Nunzi did all the machine work on my motor 10 years ago, but have had it out since. I've had a couple issues with rocker studs in it over the last couple of years and I could use some help. Nunzi installed the screw in rocker studs on my car and a couple of years ago, one of the rockers came loose. Luckily, I shut down and all that happened was my valve cover got dented from the inside, but the push rod was still up top and nothing horrible. My rockers are Crane roller tip. I bought a new pushrod and a new rocker, and installed Poly Locks to put that issue to bed. Fast forward a year and while on a leisurely ride, she started to misfire. Pulled over and found a a broken rocker stud... same valve as the other issue. Easy enough to replace the stud, but cannot have this all the time. What would cause this? How do I solve permanently?
