Ohio_Rockstar
- Mar 11, 2015
I have a 2002 year end (2003) Pontiac Montana, its AWD.
It has 138,940 on her.
I bought her two and a half years ago for $3200.
This thing had one previous owner and she used it as a Yoder-Toter. (She hauled the Amish to stores and what not).
She was my buddy haul'in late night summer fishing trip vehicle.
Okay enter my denial:
And this winter in Ohio we had -20+ temps. One day the wifey was taking her to work and she decided to not put out heat. Well I thought it was the thermostat again. (I replaced it when I first got the van.)
I replaced the thermostat. Then I got a coolant flush at Valvoline.
They burped the engine. Then I noticed I still wasn't getting any heat.
Then I noticed when I accelerated the gauge would fluctuate and then drop to normal and then Id get heat.
Well I replaced the ETI(?). The little spark-plug-like thermal sensor that goes into the thermostat housing.
Then I burped the engine. On a steep hill. At a very insane incline.
Then I talked to a few people. They said it might be the water pump wasn't working. I replaced (even though it wasn't broken.)
Took it to my cousins shop. She and her husband scanned it for me and determined I had some kind of head/head-gasket/possible manifold/manifold gasket related problem; along with transmission errors.
To break it down.
I have replaced:
Water Pump.
Power steering Pump.
ETI sensor
Thermostat.
Blower Fan resistor fuse.
All 4 tires.
Breaks are new this year as well.
Here are the codes she's throwing:
C1216 EBCM Command Pressure Release 2 Long
C1224 Right Rear Speed Sensor No Signal
C1228 Right Rear Speed Sensor Signal Erratic
C1234 Left Rear Speed Sensor Circuit Open/Short
C1235 Right Rear Speed Sensor Circuit Open/Short
C1236 Low System Supply Voltage
C1237 High System Supply Voltage
P1811 Maximum Adapt & Long Shift
One of my rear CV boots is broken.
Anti-freeze-Lower Intake leaking
Differential needs servicing.
Power steering has a rack leak.
Rack and Pinion has leaking seals.
Valve cover Gaskets need replaced.
ABS is On, AWD disabled.
Now you guys tell me what would you do?
I have a little less then $4k to work with.
Should I do the gaskets myself and hunt down the ABS problems?
What about the transmission?
None of these problems hit us until we had the deep freeze.
No garage.
I know nothing of transmissions.
I am just a novice backyard/shade-tree mechanic.
Should I scrap her and get something else?
You guys tell me what you would do?
Thank you in advance.
To break it down.
I have replaced:
Water Pump.
ETI sensor
Thermostat.
All 4 tires.
No garage.
