Some heat coming out of the oil fill cap
technobandit96
so I when to fill up my oil in my van, and I had a low engine oil message. I filled it up but right when I started doing so, I had this issue. Searched this problem on google and my results were a bad intake valve stem or the piston rings are bad! Is this a worthy task of fixing daily or is it something that I should scrap and move on? I also have a service manual that I can use if need be.
Totally unclear what issue you had when adding oil to your engine?
