djw&cjw71lemans
I have a weird problem. My 71 Lemans 350 is having very intermittent issue where the car will run and drive fine for days etc and then all of a sudden last Saturday the engine stalled. In order to start it you have to hold your foot nearly to the floor and pretty much keep your foot into it while limping it home shifting in and out of neutral/drive to keep the engine running. It will stall if you don't keep your foot into it etc. The car had been driven quite a bit on Saturday and previously with no problems at all. I did fill the tank with gas prior to this happening but then drove it for quite a bit. The other thing to note is after getting it home there was a very strong smell of gas in my garage from it but no leaks anywhere? We had a similar situation with it last fall before putting it away for the winter. But starting it up this spring etc it has been running great until now. The other weird thing to note is after all this I started it on Sunday and it seems fine. This is a car that sat for many years until last summer when I drained all the fluids etc and got the car running etc. I am suspecting possible fuel pump but looking for any input. Also about a good replacement fuel pump. Thanks!
