So I have the strangest issue I have ever come across. My '02 Grand Am GT will crank when the ignition in the acc position and you depress the brake pedal. This is NOT when the key is is the crank position. I have determined that if I disconnect the brake light switch - this problem goes away, but I then do not have operational brake lights. Thoughts ??????????
