starting issues
69Lemans350
My 350 2 barrel in the morning in about 25 degrees is sparatically puttering and stalling untill its warmed up than runs fine... What's the problem?
Sounds like the choke is too tight.
I tried that didn't work what else could have been
Is the choke closing? also did you check that the vacuum pulloff is opening the choke a little when the car starts. There should be a spec for this. Usually it is checked with a drill bit.
