Stock 326 2-bbl cam specs
thinman56
I was trying to find the cam specs for the stock 2-bbl engine for comparison purposes, couldn't find 'em anywhere. Like to know what the baseline is for when I change the cam, which will probably happen next winter along with other mods. Anyway, in case anyone else is interested, here's what I found in a shop manual:
P/N 537441, ID stamp E;
Intake - 269 degrees duration, .374" lift, opens 22 degrees BTC, close 67 degrees ABC;
Exhaust - 277 degrees duration, .406" lift, opens 72 degrees BBC, closes 25 degrees ATC.
Can't wait to start takin' it apart!
thanks for the post
