sunfire lights
platinumills
i have 01 sunfire with no turn signals or brake lights. 3rd brake light doesnt work either. i already changed the multi function switch, brake switch...fuses good. changed flasher...
help me please. cant drive it
have you pulled out the light housing,the left rear light is where all the wiring goes to,check for broken wires or bad plugs,use a test light at the plugs to check for good ground and power. all your lights back there run on one ground wire.
