T400 transmission mount
69catguy
Member
The mount that came with the car has offset holes they are not in a straight line. The 2 bolt holes on the transmission are in a straight line. Doesn’t seem correct. When I bolt it to the transmission the mount sits crooked. Looks like it won’t sit in the crossmember square.
You have the wrong mount.
All the parts stores show the mount with the offset holes.
Are you sure you have a TH400 and not a TH350?
Thats not the right tranny mount ames lists , my 70 has offset holes with one stud not two threaded holes, the mount sits angled. The first time I saw it I thought a bolt fell out but no its angled. Not sure if its a Catalina thing but Rock auto sells the angle one that fits.
im parting out a 69 catalina with a 400 auto it well have the corect mount call george 406-5432591
Thanks. I found a standard mount with 2 straight bolt holes and 1 center mount bolt. It seemed to bolt up ok. I hope it will be ok.
It just seemed like the the way it bolted up on angle was not correct. Maybe I should take out the one I installed and put the angled one back in.
